Posted by bkpigs on September 10, 2010 at 09:36:31 from (12.69.254.226):
So I posted a while back about an A that the PO said shot oil out the exhaust. This is what I have found since I bought it.
I believe the A has a blown head gasket which would explain the water in the bottom of the oil pan and the slight loss of coolant. I did a compression test and came up with 85-95 psi on cylinders 1,3,and 4. Cylinder 2 only had about 55-60 psi which would make sense if the gasket is blown around the no. 2 cylinder. The compression test was done with the hand crank so it may actually be a little higher on all of the cylinders. I hope to get the head off this weekend and will let you know what I find from there.
Thanks for all of your suggestions from the last time.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
