Farmall 400 and round baler
Posted by DR in IL on September 10, 2010 at 11:03:05 from (216.138.60.195):
I have a Farmall 400. What round balers would be compatible with it? My fields aren't flat, some slight grades but no real hills. I know Vermeer makes a Rebel that is rated as needing only 45 HP but they are relatively new and probably out of my price range. I would like to stay below $5,000.00 if possible. I would also like to have an open throat baler as I undestand they are more forgiving with tough hay. Any suggestions will be greatly appreciated.
