Re: MD shut down issues
Posted by Janicholson on September 10, 2010 at 14:41:07 from (67.72.98.45):
In Reply to: Re: MD shut down issues posted by BruceS. on September 10, 2010 at 14:01:00:
There is a Mag grounding switch on the intake manifold butterfly control shaft that should shut off the mag when it is in Diesel. A secondary grounding switch could be used to shut it off if you want to, but it still needs a minute or two to idle before stopping to allow heat to normalize. Jim
