Re: PTO problem on IH856
Posted by Owen Aaland on September 10, 2010 at 15:52:18 from (65.165.246.101):
In Reply to: PTO problem on IH856 posted by Ron in ND on September 10, 2010 at 14:53:16:
The square block is threaded on the valve stem. The PTO pressure is adjusted by where the block is located on the valve stem. You will probably want to find a used valve assembly. It is $180plus from your dealer.
The valve assembly must be installed from the bottom. You can either remove the parts of the hitch that are in the way below the PTO assembly or remove the complete unit to accomplish the repair.
