Posted by D Slater on September 10, 2010 at 15:54:46 from (184.15.36.208):
In Reply to: MD shut down issues posted by BruceS. on September 10, 2010 at 13:29:39:
May check the fuel shut off valve by taking the gas line loose to see if it drips. Float and needle should have no effect when shutting gas valve off to stop engine because fuel is pulled out low enough so the needle is open anyway. If the deisel doesn't shut off completly I don't know if there would be enough compression to run with the starting valves open. Maybe if hot enough. If it slowes way down and keeps going I think its gas leaking in. 50 + years later I don't think a lot of people think about some MD tractors never had a kill switch, and that IH recomended shutting the gas off and letting them die.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
