Farmall 230 hydraulics
Posted by Massey Harris Guy on September 10, 2010 at 16:56:16 from (24.115.132.104):
Recently have been crossing to the dark side and have purchased a 230 with the touch control hyd. fasthitch. The rear end oil is very milky and needs to be changed. I was also told that the hyds feed off the trans fluid? What is the best method of flushing the hyd.
Thanks
Frank
