Re: need help removing injector stuck in block on a WD9
Posted by Jimmy King on September 10, 2010 at 17:54:32 from (66.119.9.207):
In Reply to: need help removing injector stuck in block on a WD9 posted by dwsc on September 09, 2010 at 20:49:24:
Will the tractor run or at least turn over with the starter? If so take the bolts out tie a grease rag on the injector (must be out side ) start it and the injector will come out. Have done this on a 400 D. The rag is so you can find it because it will be about 40 feet away.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
