Posted by TheDurk on September 10, 2010 at 23:51:53 from (71.251.36.224):
In Reply to: New Owner of 1966 140 posted by stromboli1025 on September 10, 2010 at 20:17:35:
I have owned a 1966 140 since 1966 (well, I was 14 when my father brought it home). She was born with a 12V negative ground generator/regulator system. You will find the regulator on the left side between the hydraulics and the air cleaner (square box with wires coming out of it) close to the serial number plate. If it's hooked up you still have a generator. If it''s gone or disconnected, then someone probably put an alternator in.
If you are going to replace the coil, don't worry about the old one, just get a 12v coil that does not need a resistor. A NAPA IC14 works fine. If there is a resistor, get rid of it. The tractor did not come with it and you don't need it.
There is lots written on here by people more knowledgeable than I about how to troubleshoot your spark problem. Search, get a test light, and start troubleshooting. It's a great tractor and I bet she's running soon.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
