Posted by BruceS. on September 11, 2010 at 04:36:08 from (76.15.41.252):
In Reply to: MD shut down issues posted by BruceS. on September 10, 2010 at 13:29:39:
I believe I've found the problem. Throttle linkage was not adjusted correctly thus not completely shutting off injection pump. When you hold the arm on the pump manually tractor shuts off with no sputtering and white smoke. As far as shutting off on gas or diesel, it seems to be an unresolved controversy. I have always shut it off on gas cause that's what the book says. It's also been said that shutting down on gas gets a more even distribution of heat thru the head. Anyway, thanks for the responses.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
