Posted by MeanGene1 on September 11, 2010 at 07:34:48 from (209.148.104.117):
In Reply to: New Owner of 1966 140 posted by stromboli1025 on September 10, 2010 at 20:17:35:
First thing I'd try, as you installed new points, is to crank it with the cap off (probably need a helper or a remote starting switch) and see if there's a series of sparks at the points as it turns- might just need a points adjustment, might be a touch of oil on the points, etc. If you've got correct gap and sparks there, the primary side is working, then you work upstream to the coil, etc. Many times a bad coil wire will snafu you, but as it was OK until you changed the points, I'd bet on that, pretty common
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
