Posted by redih on September 11, 2010 at 10:19:59 from (208.91.177.142):
In Reply to: New Owner of 1966 140 posted by stromboli1025 on September 10, 2010 at 20:17:35:
since you replaced points and condenser, making sure that the condenser wire did not turn and ground out as you tightened the nut on point and condenser. did you set point gap on high side of distb. cam? if you turn on ign.switch test lite should lite on + side of coil.by opening points test lite should lite on - side of coil. NAPA makes a set of ign. wires that are still wire. if you left wires on dist.cap while you were doing this good. if not you will have put compression stroke on tdc and see where rotor is pointed and put wires in right. good luck
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
