Posted by pete 23 on September 11, 2010 at 11:53:30 from (173.87.16.222):
In Reply to: TA Removal - 560 posted by Texas Denny on September 11, 2010 at 11:02:38:
You have to split at engine and remove input shaft and pto shaft from the front to get ta out. Only thing you can do from the back before pulling front is pull out rear output shaft. Then the overrunning clutch rollers will fall out and if you were going to elminate them you could put it back together. I have done this to get rid of the overrunning clutch completely so it doesn"t hamper trans gear roll back for just having direct drive. You are replacing TA so you need complete teardown.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
