Posted by DonNOhio on September 11, 2010 at 17:48:40 from (216.255.47.23):
In Reply to: At Wits End ! posted by DonNOhio on September 11, 2010 at 13:26:42:
Thanks for the questions and Yes to both questions. As mentioned before the ammeter shows discharge when the lights are turned on. I have 6.7 volts at the battery. At the repair shop this morning the generator had 20 amps output at 7.8 volts.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
