Posted by Adrian Billheimer on September 11, 2010 at 18:28:04 from (12.38.207.140):
In Reply to: Dip Stick on Farmall posted by Cobolt on September 11, 2010 at 18:14:27:
Most of the older farmalls only had it as an option, I believe the power units, (engine and clutch only, to power remote equipment), had it as standard equip. thus having the location to put it. If you look on the left side, (as sitting on the tractor), of the oil pan there should be two valves, one a little higher than the other, this is where you check the oil level, you may even find a sticker there or the outline or remains of one, this noted the oil level.
As for rebuilding the engine, if you're somewhat mechanically inclined, it's a peice of cake, but to do a proper job you have to split the tractor.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
