Re: New Owner of a Farmall MD...Parts???
Posted by sflem849 on September 12, 2010 at 07:48:35 from (69.197.84.192):
In Reply to: New Owner of a Farmall MD...Parts??? posted by Matt Weltz on September 12, 2010 at 06:29:57:
The top pipe is no big deal. That is why I needed mine welded up. If the hole acutally rusted out on the bottom there probably isn't much to weld to so it couldn't be fixed easily. You could probably weld a patch over it and be good to go if it is in a flat place. It sits up under the hood enough that you and the people you told would be the only ones that knew it had been repaired. It is your money so do what you see fit.
