Hold your hand over the throat of the carburetor while a helper trys to start the engine. You need good manifold vacuum to pull that atomized fuel into the engine. You may have a manifold leak, sleeves may be worn or valves not seating if there's not much suction on your hand. You actually can choke your engine this way and the engine should start. We used this method years ago when cars and trucks had mechanical fuel pumps. You could get the engine to start, but once you removed your hand the engine would die. Hal
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
