Re: Farmall C - Diesel
Posted by Athol Carr on September 12, 2010 at 17:44:57 from (222.154.177.88):
In Reply to: Farmall C - Diesel posted by Justin S. - TX on September 12, 2010 at 17:09:14:
IH France built a diesel version of the Farmall C, the Farmall Super FCD. It had a 123 cubic inch 4 cylinder diesel engine, almost identical in appearance to the gasoline engine except both the french diesel and gasoline engines moved the water pump to the top of the block behind the fan and driven by the fan shaft. IH Germany had a diesle version of the F-12 with a 132 cubic inch (3.25"x4" bore and stroke) diesel engine, the last version used in the Farmall D-25 tractor
