Posted by caterpillar guy on September 12, 2010 at 18:24:21 from (66.188.53.165):
In Reply to: 574 Throwount bearing posted by Justin Kuck on September 12, 2010 at 17:44:59:
You will have to split it to replace it. There are a few oil lines under the cover between your feet that have to be separated and while your in there you might just as weel put the clutch in too. Get the heavier clutch also,replace the pilot bearing. You can either just cut it out with the torch, or try some grease in behind the bearing with a shaft and hit the shaft to force the bearing out.I never had any luck with that. You want to be careful how hot you get the crank cutting the bearing out so you don"t damage the main crank seal.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
