Posted by Jimb2 on September 12, 2010 at 18:33:20 from (99.240.236.11):
In Reply to: 574 Throwount bearing posted by Justin Kuck on September 12, 2010 at 17:44:59:
Hi Justin, depends on several things, is there a loader on the tractor? Do you have a good work place, level floor to work on? Proper floor jacks and splitting stands and tools.On both sides of the front axle drive a block of wood between front axle and boltster to prevent front from tipping. If you are lucky it will have the long flexible hydraulic hose to the oil cooler up front and there will be enough slack to split without disconnecting oil cooler hydraulic hose. The fuel line comes off the top of the first fuel filter, the return fuel line comes apart at the firewall by the battery box. Remove large electrical from battery first, the other electrical should have a molex connector under the battery box. Then there are bolts and studs around the bell housing, there are two under the battery box. To put it back together we usually just put pressure plate and clutch disk on the shafts, push tractor almost together so that studs and bolts in bell housing are threaded and then install pressure plate bolts to flywheel thru the inspection plate at the bottom.
BE VERY CAREFUL, make sure you have proper jacks and splitting stands.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
