Re: Farmall H 6 volt battery
Posted by 36 coupe on September 13, 2010 at 05:24:17 from (216.220.251.253):
In Reply to: Re: Farmall H 6 volt battery posted by Chris Sweigert on September 06, 2010 at 12:45:39:
I think you will find the shunt coil on the cutout relay has been burned out because of the 8 volt battery.Jumping the cut out with the engine causes the heavy series coil to close the cut out points.When you shut the engine down the generator wont charge again.The shunt coil closes the cutout points as soon as the generator starts charging.The shunt coil is wound under the heavy series coil so repair is impossible.
