Re: Farmall A before and after pics
Posted by redFarmallboy on September 13, 2010 at 12:57:28 from (76.235.193.108):
In Reply to: Farmall A before and after pics posted by redFarmallboy on September 09, 2010 at 12:30:29:
Thank You! It is indeed a regular Farmall A with a Super A torque tube and hydrolic unit. The hydrolic pump runs off the generator belt and is hidden in the upper right hand corner under the hood. This tractor is almost exactly as it was when I bought it except that I switched the C touch control and ignition switch box with a Super A unit which allows me to put the battery in the correct spot and also looks better. I also added the front wheel weights. She turned 19.9 HP on the prony break. It will not be used for mowing much because I mow with an exmark and I also have a brush hog for my 340 utility. It will be a show tractor and was at the Clarksville gas and steam show in Clarksville MI just last month. Thanks!
