A good mag will throw a fat, blue spark even at cranking speed. A weak orange or yellow spark will give starting trouble as you've found. A couple quick things to check:
- Is the mag impulse coupling tripping? It should give a noticable "snap" every 1/2 revolution when cranking. If it is not snapping, the impulse needs to be cleaned, oiled and checked for a broken main spring.
- If the impulse is snapping look next at the points. Run a $ bill through them a few times to clean them up. (Use a $20 if showing off to friends...) Then reset the gap to 0.017.
If the spark is still weak be looking for failing condenser or weak coil.
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
