Re: 51 IH SC w Carter Carb UT#0-653
Posted by Ron-MO on September 13, 2010 at 18:19:57 from (174.131.231.125):
In Reply to: 51 IH SC w Carter Carb UT#0-653 posted by oldmill on September 13, 2010 at 17:39:33:
You might check your float. My C has a Carter UT, and had a leaky float. I could not find a float, so found the leak and soldered it up after opening up the leaky spot and draining/drying it out. That was about 10 years ago, and still holds up. My biggest issue is leaky needle valve, but as long as I shut off the fuel when done for the day it does ok.
