Re: 340 Utility problems
Posted by Janicholson on September 13, 2010 at 18:24:29 from (67.72.98.45):
In Reply to: 340 Utility problems posted by redFarmallboy on September 13, 2010 at 18:18:49:
They do not have a history of failure. Some times the gear can loosen on the hydraulic pump and wear the teeth from bad clearance. I would replace all the gears from the crank/cam/distributor,and pump. Make sure shafts are unworn and put locktite on the threads (torqued to spec). It will be fine. Jim
