Re: Farmall M 12 Volt Conversion.
Posted by Janicholson on September 13, 2010 at 18:27:43 from (67.72.98.45):
In Reply to: Re: Farmall M 12 Volt Conversion. posted by Stemmy on September 13, 2010 at 17:07:33:
ballast resistor reduces the voltage to the stock coil to allow it to work correctly with the 12v sys.
It is used between the ign switch, and the coil. one from a mid sixties chev, or similar dodge will be fine. Jim
