Re: Lo Boy dies under load
Posted by Janicholson on September 13, 2010 at 18:55:35 from (67.72.98.45):
In Reply to: Lo Boy dies under load posted by Captain Twining on September 13, 2010 at 18:47:11:
Fuel delivery to carb, or crud in the main jet. If there is solid continuous flow to the carb, I would clean all passages in the carb (submerging it is carb cleaner is best) then blowing out all passages.
if the flow is anemic, clean every passage from the tank pickup tube, to the screen at the carb fitting.
A leaky manifold can also mimic this problem, but is less likely. Jim
