Re: Farmall M 12 Volt Conversion.
Posted by Janicholson on September 13, 2010 at 18:58:35 from (67.72.98.45):
In Reply to: Re: Farmall M 12 Volt Conversion. posted by Stemmy on September 13, 2010 at 18:43:29:
If you get a coil that is clearly marked (12v, no external resistor needed) it fine without the resistor. Jim
