Re: Farmall M 12 Volt Conversion.
Posted by Stemmy on September 13, 2010 at 20:03:50 from (192.234.51.1):
In Reply to: Farmall M 12 Volt Conversion. posted by Stemmy on September 13, 2010 at 15:54:50:
one more question (for now lol)....
What can I use for an ignition switch, right now its setup with a toggle switch (power on/off) and a small push button for the starter, can I still use this when I do the 12 volt conv. or should I get a key type ignition switch?
