Re: Farmall M 12 Volt Conversion.
Posted by Brownie 450 on September 14, 2010 at 03:28:53 from (66.43.241.180):
In Reply to: Farmall M 12 Volt Conversion. posted by Stemmy on September 13, 2010 at 15:54:50:
You will have to elongate the mounting bracket holes & turn the bracket upside down. Use a piece of threaded rod & washers & nuts to get proper spacing to line up the belt. A smaller belt might be in order--ours takes a 42.5 inch belt now. Makes the alt. fit under the hood better. I always use a 3 wire alt.
