Posted by F-Dean on September 14, 2010 at 07:01:52 from (75.207.191.146):
In Reply to: F-20 motor exchange posted by Cory Hulliung on September 14, 2010 at 05:28:03:
All F-20s and Regulars have the same engine. The only difference in the series is the fan belt. The 1938-39 (maybe sone 1937) models had a V belt whereas the older F-20s and Regulars had a flat belt.
In addition, some of the early F-20 and Regular models may not have had the variable speed governor.
Find an engine that looks like yours and insert it. You may want to change the left side rail and tool box to match the serial number of your new engine.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
