Re: Bigger hitch for my 400?
Posted by Crazy Red Power in SE-WI on September 14, 2010 at 13:13:27 from (24.183.132.223):
In Reply to: Re: Bigger hitch for my 400? posted by mkirsch on September 14, 2010 at 12:29:57:
No arguement here. I also believe the spreader is a bit big. It's the only one I have for the time being & am trying to make do. I figure if I can keep the load over the axles, I shouldn't do too badly. I'm going to give the W6 drawbar a try. It's a 1/4" heavier & is perfectly straight. That should help my case some. I also have to turn the rear wheels around & slide them in all the way. This way I can keep the load by the carriers. I'll probably end up reinforcing the original hitch on the 400 if the W6 bar won't do.
Thanks,
Mike
