Re: 1950 M hot box
Posted by old on September 14, 2010 at 19:10:24 from (4.245.11.238):
In Reply to: Re: 1950 M hot box posted by Bob S. on September 14, 2010 at 17:45:08:
Well yes no and maybe. If you have a 12 volt coil that does not need a resister then no it will not burn the point. If you have a 6 volt coil with a resister in line yes if you run it a long time it will burn the points out faster but for what you need to do you should be more then ok. I do the hot wire thing all the time when working on tractors we get in just to get them up and running
