Re: plow info, please
Posted by Kornkurt on September 14, 2010 at 20:10:37 from (66.185.0.209):
In Reply to: Re: plow info, please posted by farmallboy15 on September 14, 2010 at 17:58:20:
The adjusting lever has been reinforced and welded. Yes, it was on steel since it was right after the war and many implements were not available on rubber. Also, it has been repainted mostly red with gold/yellow wheels. Thanks for the replies!
