Re: Farmall M 12 Volt Conversion.
Posted by Janicholson on September 14, 2010 at 20:29:54 from (199.17.6.223):
In Reply to: Re: Farmall M 12 Volt Conversion. posted by Stemmy on September 14, 2010 at 14:39:40:
There are no differences between switches for 12v and 6v. It is only necessary to assure they will carry the amps. The standard Original switch is good to go for either. Generally a 6 volt use of a 12 volt switch is OK if you select a switch with twice the amp rating of the circuit. Most are rated for 20 amps, and that is sufficient for all but starting current, and alternator output (and that is not switched) Jim
