Re: 1950 M hot box
Posted by Ron in Nebr on September 14, 2010 at 23:12:35 from (66.252.113.233):
In Reply to: 1950 M hot box posted by Bob S. on September 14, 2010 at 17:31:51:
Just an additional thought here for what it's worth....
If you've had a charger on the battery and believe there is a direct short to ground somewhere in the system, if you need to unhook the battery, take your battery cables loose where they bolt to ground, not at the battery....if there IS a direct short someplace, taking a cable clamp off the battery will likely cause a pretty good spark, and if the battery has just been on a charger, that's a good recipe for a battery explosion. Better safe than sorry.
