Re: Super M-- hard to start
Posted by El Toro on September 15, 2010 at 08:56:45 from (74.103.121.247):
In Reply to: Super M-- hard to start posted by Finnbair2020 on September 15, 2010 at 03:22:52:
Use 00 welding cable for your battery and use soldered lugs. Don't make them any longer than necessary. Make sure all connections are clean and tight. Measure your battery voltage at the starter when cranking to see how much your battery voltage drops. You may not have enough voltage left for your ignition. Try pull starting to see if it starts easier. If it starts easy your battery voltage is getting too low. When pull starting it's not dropping the battery voltage. Hal
