Re: cub runs ok,, then???
Posted by Jerry M on June 16, 2000 at 16:49:04 from (152.163.206.194):
In Reply to: cub runs ok,, then??? posted by Mike on June 16, 2000 at 16:36:11:
Sounds like the carb is gummed up.... mine was leaking gas, took it apart and cleaned it well, then it would not run at all unless I had the choke pulled all the way out. So, my guess is that you are not getting enough gas for some reason. Good luck..
Post A Followup
: Re: Re: cub runs ok,, then???
