Re: 51 IH SC w Carter Carb UT#0-653
Posted by oldmill on September 16, 2010 at 16:41:47 from (67.193.84.81):
In Reply to: Re: 51 IH SC w Carter Carb UT#0-653 posted by farmallhal on September 15, 2010 at 17:59:27:
Thanks for your comments. What model Zenith did you put on the Super C?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
