Posted by Jimb2 on September 16, 2010 at 18:00:26 from (99.240.236.11):
In Reply to: leaky pump posted by john826diesel on September 16, 2010 at 17:11:23:
Hi John, it is probably the front oil seal on the injection pump drive shaft. If you were able to remove the pump and re-install it when you had it overhauled then you should be able to replace the front oil seal. Tools required are a seal puller and a deep socket that will fit over the drive shaft and some seal lube. Becareful not to nick the shaft or the new seal on the woodruff key in the shaft. Lube the shaft well before installing the new seal and use the deep socket to seat the seal. Make sure seal goes in straight and seats properly.
I believe the part number is: 3078355R2 SEAL SEAL oil drive shaft BUT verify with CIH parts person. I searched a CIH dealer in upstate NY in stock for $10.52.
This seal wears out more frequently now with the new low sulfur Diesel fuel. So to prevent premature failure add some Diesel fuel conditioner in the Diesel tank.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
