Posted by Janicholson on September 17, 2010 at 07:19:17 from (199.17.6.36):
In Reply to: Leaking coolant posted by FFTM on September 16, 2010 at 18:42:39:
The dry sleeve is pulled. THe bore casting is machined out to fit a repair sleeve (thick) the repair sleeve is bored to accept a standard M sleeve, (or thin overbore sleeves to make it the same as a SM). Only the affected cylinder is required to be re bored. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
