Re: Farmall Regular still baffled!
Posted by oldiron29 on September 17, 2010 at 09:40:54 from (69.112.87.249):
In Reply to: Re: Farmall Regular still baffled! posted by Duanes on September 17, 2010 at 07:54:21:
Duanes, Eather to much fuel or not enough! Trial and error again 3) things need Fuel, Compression and spark. Focus on the carb float setting. If you give it some fuel than turn off the fuel at tank so you don't flood it. turn main jet screw on top of carb all the way in and back out
2 1/2 turns and go from there. Try another set of plugs gap at .25 Don't give up it will run
Oldiron29
