Re: installing bearings
Posted by El Toro on September 17, 2010 at 10:29:27 from (108.3.180.43):
In Reply to: installing bearings posted by hman on September 17, 2010 at 08:22:55:
You need to measure or have someone measure your crankshaft to see if it is egg-shaped, needs to be ground undersize or has been ground beyond the specs. You may need to split the tractor and remove the crankshaft if any machining is needed. If it needs bearings it probably needs new sleeves, rings and pistons. Hal
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
