Re: 340 farmall hydrolic oil
Posted by Al L. in Wisc. on September 17, 2010 at 15:14:18 from (216.226.95.81):
In Reply to: 340 farmall hydrolic oil posted by butch nelson on September 17, 2010 at 14:26:03:
On my first Farmall 340 hydraulic fluid change...well...I THOUGHT I had enough drain pans within easy reach; nuf said. That large rear plug, once unplugged, really drains. If you pry just a little on the rear hydraulic filter housing, you don"t have to mess w/disconnecting the left brake pedal also; I know that now. Just one hydraulic fill hole; square recessed area in round plug next to the shift lever. The check plug is below your left running board, pull down on the clutch pedal slightly and you should see it. Clean and blow the crap out of the area before removal to keep your fill hole clean. Good luck w/your project. Gotta love those Farmall 340"s.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
