Re: Delco p/n 1111411 distributor on H Farmall
Posted by Janicholson on September 17, 2010 at 18:36:15 from (67.72.98.58):
In Reply to: Delco p/n 1111411 distributor on H Farmall posted by Bob And on September 17, 2010 at 18:22:39:
The Delco does have advance components. They can be checked (to a limited degree) by gently turning the rotor by hand, in the same direction as rotation, it should turn a few degrees against spring pressure, then when released it should spring back.
Rich mixtures almost always are carburation, or air supply. Set the static timing to TDC. and check it with a timing light to assess the advance. Jim
