Re: Stanadyne 656 questions
Posted by Bob on September 18, 2010 at 11:01:03 from (69.178.228.68):
In Reply to: Stanadyne 656 questions posted by Tom/Idaho on September 18, 2010 at 06:17:34:
You CANNOT pump that kind of pressure into the return fitting.
If you feel comfortable doing this, you can take the top cover off of the IP and see if the metering valve is "free".
***WARNING***
If you muck the governor linkage up in that area and the engine starts, it will run wild and you won't be able to shut it down.
