Posted by D Slater on September 18, 2010 at 18:10:08 from (184.15.13.17):
In Reply to: 400 Farmall TA posted by 400D tractorman on September 18, 2010 at 17:08:29:
If the clutch linkages are adjusted to the best they can be. The T/A clutch is not releasing or staying released. If the t/a clutch pressure plate and release bearing is good, check for lining comming loose on clutch plate or oil getting on it. Also check that the clutch carrier is not loose due to the retaining nut backing off. Other possibilities is a problem with the planet gears, shafts or bearings in the t/a unit that makes them not want to turn free when in t/a. If planet gears don't want to turn or lock up completly, the whole planet carrier unit turns as one unit just like in dirrect drive t/a even though the t/a clutch would be released. Another thing I was about to forget is sometimes the coupling between the t/a drive shaft and t/a sun gear shaft will slide back on the splines and keep pressure to the t/a clutch plate after release. They added a clip inside later splined couplings to keep that from happening.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
