Re: installing bearings
Posted by truckinthumbtack on September 19, 2010 at 10:33:35 from (204.116.207.73):
In Reply to: installing bearings posted by hman on September 17, 2010 at 08:22:55:
You are referring to what is called as "rolling" them in. To remove them. Remove one main or rod cap at a time. Roll out the old bearing. This is done by pushing on the side of the bearing that does not have the notch on it. Use some thing soft that will not mar the crank!!! I.E. thin piece of plastic etc. When you get the old bearing out. On the back of it it will say "STD" if standard or .010 for undersizes, etc. Like the other gentlemen said though. Installation is reverse. If you need to do this, chances are the sleeves and pistons need attention too. Your crank may even be scored or as mentioned "egg shaped" to the point it needs turned anyhow. So you'd be wasting your time.
