Re: Points ignition causing alternator damage?
Posted by John M on September 19, 2010 at 15:37:38 from (67.231.160.184):
In Reply to: Points ignition causing alternator damage? posted by n9viw on September 19, 2010 at 13:42:10:
"The second thing I found was that he had neglected to wire ANYTHING to the regulator- no sense lead, no excite wire. Nothing! I found this out after I kept burning out coils (and then resistors, after I learned a thing or two about 6-to-12v conversions), as the alternator was putting out who knows how many volts, unregulated."
Is there such thing as a 10si that uses an external regulator? Ive never heard of one, so if your wiring in a regualtor, theres the problem! Second thing is if your buring coils, you definatley have something wrong....
