I take it you have a Delco with the 2 terminals for field & sense on the back of the alternator as opposed to the internal regulator models having the 2 connections on the circumference of the case. Also separate regulator. Looking at the regulator there are 4 prongs [spade connectors] on the right side of the regulator. The top lug goes to the switch [turn on]. The middle 2 lugs need not be used, but connect to the idiot light. The bottom lug should connect to the field or right of the 2 terminals on the alternator. The left terminal on the alternator doesn't need connected, but deals with the idiot light also. The large terminal on the alternator goes directly to the ammeter if it is there or to the starter battery terminal on the solenoid. Make sure there is a good ground connection from alternator to regulator & also frame. Hope this helps.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
