Re: Delco p/n 1111411 distributor on H Farmall
Posted by TheDurk on September 19, 2010 at 17:02:13 from (71.251.34.41):
In Reply to: Delco p/n 1111411 distributor on H Farmall posted by CNKS on September 17, 2010 at 18:22:39:
You don't need to actually time anything precisely, so a chalk mark anywhere on the rim of the crank pulley will do. It should move up and down with engine rpm's under the timing light. That will tell you the advance has some function or not.
